you would need a coat over everything to give it the same suction
f**k me you ask stupid questions
Anyone put waterpoofer in Weber OCR?...just been speaking to technical and apparently it's ok...got a job that needs alot of dubbing out over Rendaid.
Use hardwall u plumThis is the problem I'm having...why don't Weber have a dubbing out render, that could be used on top of Rend Aid before OCR. OCR then Rend Aid again seems illogical.
That solution is too simple to be the solution......Or maybe that solution was the obvious solutionJust dub out the bits over your rend aid then paint a coat of rend aid over the dubbed bits couple of days after if it makes you sleep better mate
