Daniel Haigh
Hi what is that magnetic plaster like to use I know they say you can just pva and skim with it like multi but is it that easy? Thanks
At 4-6mm what sort of coverage per bag would you expect per bag?is that that the specified depth?i would like to use it when I get the chance,at the price it's not something you can just have a go at unless you want it in your own home.Doesn't like going on too heavy and you need to be between 4 and 6mm for best stickyness
NopeAny bags left over for me danny?
5m2 is about right... but I seemed to get more on... I will find some shots when I get back home and post them to give an idea how far it wentAt 4-6mm what sort of coverage per bag would you expect per bag?is that that the specified depth?i would like to use it when I get the chance,at the price it's not something you can just have a go at unless you want it in your own home.
Haha we did that... photos don't stick up there now :-/Around 5m a bag but you could stretch it by being tight at the tops of the walls which your not gonna use the space.
Ok moody bumNope
You can pop in and see my walls I'd you like though xxxOk moody bum
Alot easier on new boards or quite flat walls CUs if u overskim a all over the place wall u find it hard to get the depth needed for the weaker magnets to work 5mm at leastHi what is that magnetic plaster like to use I know they say you can just pva and skim with it like multi but is it that easy? Thanks
Is that a youthism?You can pop in and see my walls I'd you like though xxx
If you want it to be xxxxIs that a youthism?
Ooo ill make my excuses with the mrsIf you want it to be xxxx
Why?My plan when or if i get to use it would be to lay on 3mm then flatten and run a light brush through it. Leave for 2/3 hours and apply a second 3mm and finish.
Why?
So im over thinking it, just slap it on in one hit?
I'm lost, can you simplify that equation flynnymarra.................................How I do it is quite simple if it's a Five metre wall use one full bag if it's ten metres use two![]()
I didn't want to overload people with figures but if the wall is 7 and a half metres use a bag and a halfI'm lost, can you simplify that equation flynnymarra.................................![]()
Cheers guys any idea were is the cheapest place to get a bag then
First4magnets do £75 a bag plus deliveryCheers guys any idea were is the cheapest place to get a bag then
Thanks enjoyed that one...have u put any thing on your walls at yours yet.. Ikea do some good office stufflooks good![]()
