Ive just used it last week.
About 80 including vat from SIG.
I used it on old Victorian walls, stone work with the old black mortar and brick internals.
I've been doing it at 3:1. It's works but I'd be tempted to do it neat on the other bricks walls I have left.
Still sucks a fair bit.
Don't believe there coverage either it doesn't go that far.
They say at 6:1 with water it can go to 600m2.
At 3:1 I've been using its covered about 200
The stronger the better but then it will eat it up!
Do u need to leave it until dry like bond it.Ive just used it last week.
Serious?, F*****g cheeky bg!It's sbr mate, get the big tubs on eBay
50-50 mix ?Glasgow area,
High suction sand,lime walls with finishing off,picture rails etc,,,
I have had previous issues with pva,
3 coats and still sucks like f***
Drying it out too quick then crazing.
U know Victorian building.
Really don't want to take any chances on this one.never used the stuff but any alternative ideas welcome.
Never used sbr,but if anyone has tried it using plaster on top of it I would be interested to know.
Though I can't risk a f*** on this project.
James what is knauf version called.Ive used the knauf version and found it good at killing suction, i sometimes throw a little of the betakontakt in with it to give a bit of key.
Where do you get it from jim? I tried a knauf supplier in cov and they wanted £70 for a tubIve used the knauf version and found it good at killing suction, i sometimes throw a little of the betakontakt in with it to give a bit of key.
Its called high suction primer.James what is knauf version called.
Sent from my GT-I9195 using Tapatalk
have you tried using a stabilizer on the wall first then pva or grit coat as the stabilizer really does hold the suction back and you can get it from tool&fix for around £8.00 for 5 litresGlasgow area,
Depends on the ratio pal. Neat will waterproof but I find a 4-1 on high suction such as grey skim it just holds it back nice...Why do people treat sbr like Pva and let it set? [emoji30] I thought it becomes water proof once it sets?
How did this job end up mate , what did you end up using , I've been back on the gyprime today and forgot how good it is , just been telling my mate to get some but he is tight and won't take my advice that gyprime is the bestThanks for your feedback,I have found out cementone do it stabilizing and pre grit which I have used before which will do the job,says it primes as well,half the cost as gyprime,though don't know how it will cover as well.
Job was fine,,,,i only use cementone now,,,decent flow of it,decent price,How did this job end up mate , what did you end up using , I've been back on the gyprime today and forgot how good it is , just been telling my mate to get some but he is tight and won't take my advice that gyprime is the best
How much is the cementone and roughly m2 per tub? , with gyprime get 400m2 - 600m2 watered down at 4/5 to 1Job was fine,,,,i only use cementone now,,,decent flow of it,decent price,
Gyprime overpriced.
Cementone is equivalent to thistle bond it,,, but kills high suction backgrounds,,,How much is the cementone and roughly m2 per tub? , with gyprime get 400m2 - 600m2 watered down at 4/5 to 1
I have only ever used it on block work,not a alternative to grit for skims for me,,,not designed for skims Vince.It's definitely ok to skim over mate![]()
Serious mate, well I'm not gonna phone Bg technical department and tell them there wrong.I have only ever used it on block work,not a alternative to grit for skims for me,,,not designed for skims Vince.
You should do reallySerious mate, well I'm not gonna phone Bg technical department and tell them there wrong.
