Plasterers1StopShop
The best way to predict the future is to simply create it - The M-tec M200 is the latest 110v machine suitable for Renders and Plasters for the UK Market
Manufactured in Germany by M-tec, the new M200 machine has been designed using the best of their engineers working jointly with Andrew Hill from Plasterers 1 Stop Shop. Based on their expert insights and identifying priorities and productivity the UK specification was created, known as the ‘AJH Design’.
Not to take all the credit, the creation of the M200 was also based on expert insights and opinions from our customers, identifying their priorities, needs and practical onsite knowledge. It was important for us to listen to what our customers said, to guarantee an innovative development of the new M200
The principal objectives in this joint design venture was;
Quick and easy Rotor & Stator coupling, a specially designed Mixing shaft & chamber, allowing the same parts to be used on Renders & Plasters
OUTPUT
With an output of up-to 18l/min, the M200 will give the larger machines a run for their money, especially with a pumping distance of 25m
The M200 comes with a built-in 4 way speed control, the M200 has the ability to spray a wide range of products at different speeds. More importantly, you do not need to change parts to spray different applications. I.e. Monocouche Renders to Roughcasting to Thin-coats
There is simply no job too big or too small for this machine – it’s the perfect partner for either the domestic or commercial contractor
BENEFITS
The M200 comes complete with the new EZE Gun, which features an automatic material/air shut-off valve. Thus reducing any mess when turning the machine off
The new EZE Gun can also be used to spray textured finishes and basecoats for the EWI market
The precise clear design of the controls and abandonment of redundant switches makes the machine simple to use.
In very little time and with minimal effort, the machine can be disassembled – a huge advantage on the construction site
SPECIFICATION
Standard delivery volume Up-to 18l/min**
Conveying distance 25m**
Conveying Height 10m**
Conveying Pressure 25 bar**
Drive Motor 1.5kW
Electrical connections 110v 50Hz 1ph
Fuse 32 AMP
Connecting Cable 3 x 2,5mm
Connector 32A 3P 6h
Water Supply 3/4" water Hose with GeKa coupling
Water Supply Min water pressure 1.8bar whilst machine in operation
Dimensions 1170 x 590 x 1060mm
Weight Less than 115kg
**Depending on consistency, quality and composition of the material, pump model and - condition, diameter and length of the delivery hose and also the pumping height of the material
Scope of delivery:
- Method, ease and practicality of use
- Overall effectiveness & performance
- Economical concept
- Working Volume
- Focus on design and practicality
OUTPUT
BENEFITS
SPECIFICATION
Drive Motor 1.5kW
Fuse 32 AMP
Connector 32A 3P 6h
Scope of delivery:
- Mixing Pump - M200 including:
- Air Compressor
- 20m Rondo hose and Air line – Rondo Hose = 1 x 10m 25mm + 2 x 5m 25mm
- Mortar Pressure gauge
- Flow meter
- Tool kit
- 20m Water Hose
- Small water barrel
- Electric cable
- EZE Gun - the unique and new spray gun for the use of Render and Thin coat
- Water Pump
- Cleaning Coupling
PRICE: £5995.00 + VAT
For more information please visit: https://www.plasterers1stopshop.co.uk/m200-p-801.html or call us on 01242 236699
