I would just use a 2mm texture and it'll leave it like a tyrolean finishhi lads I'm hoping to spray a light Tyrolean with mono, and obviously need it as tight & uniform as possible, the mono will be sprayed with a ump 1 3 phase machine, then hoping to use a hopper gun or bennu x15, has anywone got any experience in this?
3mm texture looks like Tyrolean
It's like spreading marbles though. Got to be better sprayed.
They are ment to be a nice tight finish mate.only thing I don't like about them is I do quiet a few balconies ceilings with the eze 24 which are eze but you would struggle with one of these and there's the scaffold where you would struggle with the gopper in the way. But I have thought about one for smaller jobs, let me know how you get on mateI've ordered a bennu spray gun should be here on Tuesday anyone used one
Am hoping it will be sound on my jobs as I only do 100m2-200m2 houses so should fly through themTh
Hope so mate keep me posted pleaseAm hoping it will be sound on my jobs as I only do 100m2-200m2 houses so should fly through them
Do you not spray your top coats at allI like the thought of using one as I'm doing thin coat work a lot now
I've seen the finish close up and I've said it before it gives a tyrolean type finish even using 1.5mm texture
It's not flat enough for me
Get some close up pics on @JerseyboyGot my new bennu spray gun on Wednesday and have been using it.
It does work well and if I am doing small jobs from 10 m2-150m2 I will use it.
Leaves a tidy finish and 15 mins to clean it when finished.
Ok mate will get some pictures on Monday when am doing the gable
How will you be able to take pics if youm spraying a gableOk mate will get some pictures on Monday when am doing the gable
My LabourerHow will you be able to take pics if youm spraying a gable
Lol I was pulling ya chain mateMy Labourer
Do u work alone?????????
I will stick my head cam on and get some great picturesLol I was pulling ya chain mate
Your right if the basecoat isn't perfect it shows but hand applied hides most imperfectionsLooks good jersey. It's nice how easy it is to do isn't it. Stop and start no bother.
I've used a hopper gun and it's a similar finish. 1mm looks good but the base needs to be 100%.
I still think hand applying leaves a nicer flatter finish and it's more forgiving on a base that might not have finished perfect.
