are you gonna prep the whole 100 mts first?
If so do ur first pass 600 mm over the 2nd section you are doing then spray ur 2nd pass 300 mm over the 2 nd section and the 3 rd pass where you would like to finish for the day. Then just carry on next day with ur first pass 2 nd pass and final. You wont see any joints because ur only spraying the texture on
I've got 100m2 or OCR to do, cullamix on top. Is there a bead I can use to split it in 2 manageable panels...which I can then Tyrolean over the beads so they can't be seen.
I was thinking a stop bead...but will the Tyrolean take to the bead.
Don't Tyrolean straight onto the ocr
paint the cullamix on first , then spray itWhy not bob?
Surely you want expansion beads any way, change of height,weight and direction all have an influence on where,how and why you would use an expansion bead,even if the brick or blockwork has mortar bed reinforcement this panel is still to big I'd say.
What colour tyrolean is it? I would be using an expansion bead on a panel this big but I would try and get a bead near to the tyro colour.
I don't know why your worried about a join cos you paint your cullamix jobs anyway so the paint will hide any join
this info contradicts webers 'best practise guide' available for free if you call their tech.not saying your lying,it just seems strange that weber have two contradicting texts.I thought so to but then i saw this on the Weber website...
In our experience, cracking of the substrate can be considerably minimised if the bed joint
reinforcement is used specifically around openings. From the rendering contractor’s
perspective, movement joints in the substrate must always be reflected through the render
coat. There is no benefit in having movement joints in the render alone, other than to form
a day work joint.
I highly doubt there will be any movement joints in the brickwork as the property is old.
What is tyrolean
Its FreeD's skimming......................................:RpS_laugh:
