FreeD
Hi all just taken on my biggest job so far complete re rend of gable end bungalow...got majority of render off today but came across a couple of probs.
Firstly no bellcast bead on the bottom render came out apprx 40mm from wall...not sure how to match up with rest of house do u use a 40mm wooden batten if so how do i fix this to wall? or should i use a bellcast bead?
At the edge of the wall do i just leave a bit of render on? as i don't want to damage render on adjoining wall or is it best to take this off and use bead?
And the other problem is carport roof screwed into wall...quote is to replace flashing after...would you just remore flashing and as much render as possible top and bottom? or remove the whole carport?!
thanks
Aaron
thanks
Aaron
