hi all I got a small extension t render never done it before just need bit of advice I can float and set no problems at all.
the customer wants all stainless beads including bell bead along the bottom what size bead should I use I think they come in 10mm or 15mm?? ( the block work is thermulite blocks)
also do you scratch coat the wall before beading up or bead up as you wounld internally??
also across the head of the window would you use a bell bead or just a normal corner bead??
do you put the waterproofer in both coats or just the scratch coat??
thanks for you time
ashley
thanks for you time
ashley
