Small but awkward concrete pour
Give it a go. I’d prob bore the passengers to death though, so would be more like a private ambulance
Or you could just recite your diary's to the poor unfortunate souls, they'd never laugh or even smile again .
That should be "all" the tip that you were craving !
You absolute monster !!! :oops:
Screw fix do their own brand deep levelling screed. Couple bags and will be like it never happened (y)
Perfect that's what I'll do cheers :)
Did you add sharp sand to the mix or just ballast? Did you handbash it?
Just ballast, done by hand. Ballast been sat on my drive for 2 years and had weeds growing in it. Probably didn't help my cause. The good news is I had 2 bags of cement also 2 years old that I thankfully threw out as tempting as it was to use them.
Just ballast, done by hand. Ballast been sat on my drive for 2 years and had weeds growing in it. Probably didn't help my cause. The good news is I had 2 bags of cement also 2 years old that I thankfully threw out two years ago
Be fine, it will just age the overall character of said bodged endeavour/effort/ f28ck u%
God favours a bodger mate (y)
Haha indeed.
Speaking of bodge the wall had 2 block pavers and spray foam used by previous owner to patch the wall for whatever reason. Just so happened to find 7 bricks on my floor dig and was able to brick it up properly.
You win some you loose some.
The concrete came out ok. After I scrapped back the top sandy layer it is looking much better and rock solid.
+ 2 coats SBR
  • Small but awkward concrete pour
Got my wall base plates on nice and square. Definitely did keep the moisture in or I tried to drill too early as the first 2 the concrete was too weak so I glued/foamed them (solid). Waited a couple of days and got the final one on today. Concrete solid.
Also stripped some plaster and fit the ceiling insulation.
Gonna wait another week before self levelling
Haha indeed.
Did you buy this house from @ChrispyUK ? It has all the hallmarks of his approach to construction.
Haha the house is a mess. The guy who sold it was old school. Do it all yourself and use what you have laying around. It's a miss match of bodge jobs.
But I've renovated all rooms over the last 5 years. This tiny toilet is the last room to be done, I'm going to do it all myself apart from electrics.
I'm going to take that as a yes.
You are of course right in saying that @ChrispyUK is old skool, he basically pioneered holding properties together with foam.
Finally got around to doing the self leveling. First go doing it, happy with the look. Gave it another coat of SBR, waited 2 hours for it to dry. Used a trowel to spread it and went over it a couple of times with a spiked roller.
The real test will be tomorrow with a level ;)
