What was the Substrate ? If you used a descent sand and gauged the waterproofer , i would definitely not wet it down and even if you didn't i would think twice, and rendering this time of year wants to be on the wall by 10. 30 am mix it up as stiff as you can use it ,the wall my look dry before you start but once a bit of moisture gets on it from the top coat the waterproofer will start working and will hang around wet all day and make sure you have a good 1st coat key and push the top coat right into that key . Good luck and do you have any site light s ;D ?
