Exactly my opinion aswell, if there's no cracks in existing angles I don't bother, obvious cracks etc yea.Paper tape over any cracks or signs of background movement.
If its a re-skim and no movement or cracks on internal angles then can't see the reason for scrim or paper tape.
Why?How many of you Scrim the angles on re skims ?
Why?
I wouldn’t fancy skimming a full flat over blue grit!Just doing a job for a joiner, first job I've done for him, he's asking if I've scrimmed all joints because he doesn't want any cracking, a full flat has been bluegritted
Exactly, I would normally Scrim cracks and joints before the bluegrit, nope first day on job and all gritted, its s**t skimming on it anyway never-ending trying to get over grit plus scrimI wouldn’t fancy skimming a full flat over blue grit!
Hopefully you have you have skrimed before putting that s**t on?
Exactly this. If it's not cracked in 10years plus or whenever it was last plastered then why would it now.Exactly my opinion aswell, if there's no cracks in existing angles I don't bother, obvious cracks etc yea.
And here the lesson ends!Exactly this. If it's not cracked in 10years plus or whenever it was last plastered then why would it now.
Normal plasterboard in bathroom, not scrimming angles and still earn more a day than @carl-the-plasterer ever did![]()
in ye fkin dreams you ruff pleb I doubt you're even a fkin spread at all with the shiiit ye chat on hereExactly this. If it's not cracked in 10years plus or whenever it was last plastered then why would it now.
I beaded up once and lab blue gritted my f**k**g BEADS.I wouldn’t fancy skimming a full flat over blue grit!
Why the f**k would there be an angle round a socket or switch?Real pros scrim the angles around all sockets & switches ceiling wall abutments
.. End of...
Your welcome
So easy to wind upin ye fkin dreams you ruff pleb I doubt you're even a fkin spread at all with the shiiit ye chat on here
Puddled !Real pros scrim the angles around all sockets & switches ceiling wall abutments
.. End of...
Your welcome
To be honest how many scrim anything lolHow many of you Scrim the angles on re skims ?
u couldn't wind up a fkin wrist watch u limp wristed slagSo easy to wind up![]()
What's scrimTo be honest how many scrim anything lol
What's scrim
f**k*d if i know. This man is scrimmed up. Why the f**k people are doing that on building sites i dont knowWhat's scrim
You sound wound upu couldn't wind up a fkin wrist watch u limp wristed slag
There is no angle that could possibly crack on a plug socket.... Please explain how it could and why you would need to scrim itErm.. because it's a 2-dimensional shape?
Generally, a socket cutout has four 90degree angles, which means it's a square or rectangle.
...or do you always work with circular or elliptical socket and switch cutouts?
He didn't say angle-beads.
He said angles.
Beads are not designed to be scrimed over and it is actually a weaker joint with scrim down the bead.
I am a world authority on beads and tape and have an Ology to prove it.
Agreedu couldn't wind up a fkin wrist watch u limp wristed slag
He's abit slowInternal angles pal.
This should be interesting
I've learnt some people "scrim the angles of sockets" and others are so determined to try and make the genius on this site wrong about something that they chime in and agree this might be a good idea.This evening, you've learned that there are 4 angles in a rectangle.
I can't be responsible for telling you everything - that's the job of the television.
