Screeding help needed
Mucky
Hi guys, I've got a bit of a problem with a area that's out side a back door of a house that has got a concreted area that is two different levels. Basically the area is about 10 feet long and 2 feet deep and I've got to make up about an inch on the deepest part going down to half an inch along the length and feathering out to nothing on the depth. So first question , can I screed that shallow without it breaking up? And how do I do it?
Why not use an Ardex primer and levelling compound ,you can get a good build with Ardex
I probably should have said that it's a rental we are doing up and we are going to tile or paint it depending in what levels / finish we can obtain. We just want to make it safe so no one trips up.
Just dig it out ,1" of concrete screed even with sbr is likely to blow off the base
