renovating plaster
brimplas1
hi chaps just after a bit of info on lime lite renovating plaster, i have a tanking job coming up which i would like to use this on as its an external wall which cannot be injected...... i take it i have to scud the tanking before rendering ! could i build out the thickness in one coat (two passes) compared to sand and cement as the last time i used sand and cement on tanking it slid all over the place and had to keep the scratch coat very thin and if i need to do 2 separate coats do i need to scud the scratch like you do when using sbr ? thanks in advance for any help...
I normally render 1st then tanking on top, scud then renovating plaster. Are you doing it in 2 passes to build it out?
Sent from my D2303 using Tapatalk
Yeh I ending up using parex version of it £18 a bag u might get it in one if thick enough ,the limelite Travis sell Not stocking it
When I have used normal render on the tanking in the past it has sagged and slipped so did only did the scratch about 5mm thick. Knowing my luck the existing plaster I have to tie into will be 30mm thick.....lol. my local Travis say next day delivery on the lime lite.. £25 with the vat.
It's like hardwall, you get abit of Lee way with it thickness wise. Not sure about limelite but the gear I use you leave it 15 mins once it's mixed so don't worry if you mix it slight wet cos it will pick up
Ta Arti. May seem a stupid question but do you add water to powder or powder to water ... just with it being light weight...
Cool, how long till skimming ? I am using sand and cement on other parts of the job and usually leave 7 days.
24 hours. No need to PVA before skimming just bang it on. Hangs abit as well so plenty time for brews between trowels ;-)
At £10 a pop at Bnq at mo
Message to BG can u change the price to £6.00 please:baba:. otherwise I'm shopping at knauf !!
Good to know pal as I have an account with them but must spend £60 to get free delivery.. its only a small meterage job I need it for...
I use renderlite from sovereign, usually do the usual tanking spec then depending on the job its renderlite as we all know s&c slides on tanking. Not had a problem with it.
Saves you time and also its not as cold as s&c so its more thermally efficient.
What ever you do don't wet the wall if your going on tanking, just scratch it then top coat it, you will have a nightmare if you go for one coat. but depends how much your building out if its up to 15mm you can do one coat but any more its 2 coats.
Just try it a few times and you will be surprised how much you can get on. If you can float it in one go for it. :bananahappy:
Yeah do your normal sbr render with s&c as the backing coat, tank as normal then you put on the renderlite then skim.
Use the renderlite for the float coat/s
