Refina
And Finally!!
The s*p*r*lex is a stainless steel spatula with an ultra flexible used for flattening and levelling large areas of skim plaster
Customer comments
“Might have been done to death but I tried the s*p*r*lex spatula for the first time ever today and its awesome. Laid gear down with the normal steel trowel, then just used s*p*r*lex and finally the plazi to flatten and finish. As good as any walls I've ever skimmed, with plenty of 'sit down' time. I'm confident I could get way more on than usual, using these babies. Nice shaped stainless steel blade can get into corners very well. The size of the spatula means I can smooth out a sponged wall in no time. This allows me to use the s*p*r*lex on a pole over a sponged ceiling with no snags or misses in the plaster, unlike flattening non sponged plaster”
“The design of the s*p*r*lex is easy on the wrists meaning an effortless set. Applying pressure is easy. Once the sponge lines are flat I can then use the s*p*r*lex spatula to finish the wall/ceiling area in a good time and with less pressure on the wrists”
“Basically I sponge the plaster allowing us to use a s*p*r*lex again. As I do a lot of domestic work, the walls are a bit uneven so I use the 600cm spat and found it covered the wall with no missed areas or snags”
“We have been trying sponge methods and have used a range of tools. Recently I have been using the s*p*r*lex spats to flatten in sponged plaster, this has worked so well for several reasons. When flattening and trowelling in sponge lines, it can take time and be hard work on the wrist as we need to apply a decent amount of pressure to remove them. Allow 3-5 minutes until the sponge lines are not so wet and have started to firm up again as you don’t want to flatten it in while still really wet as you will just take off the surface. Wait a short while and trowel with the spatula. Clean up get ready for next set and return to wall for a quick polish up with spat. By using the spats, it speeds up the set and make life so easy”
“Flatten quickly with a s*p*r*lex spatula to remove lines and tidy up. Once ready tidy up corners and trowel over wall by hand with a steel trowel filling in any missed areas, the wall still a bit wet at this stage”
Customer comments
