Meirion Harries
Hello
I plan to strip off all the cement render at the back of my Victorian house. I will be removing the existing render myself but I then would like a tradesman to do the following:
1. Re-point the brick face in lime mortar where needed
2. Fixing wood wool boards in place as a thermal layer
3. Re-rendering the outside of the building in hydraulic lime
The area is between 35-40 square meters. One guy gave me a quote of £5200 for rendering and applying a lime wash with all materials - this doesn't include hacking off or the cost of the scaffolding. What's your thoughts on this quote? He has a very good reputation/reviews.
By the way I've decided now to finish the exterior in a breathable silicate masonry paint compatible with lime.
What's your thoughts on fitting the wool boards directly into masonry?
Do I need to purchase a seperate base coat/top coat or can 1 type of lime render be used for both?
What kind of mesh roll is best and do I need it if I am boarding out?
Regards
Meirion
Regards
Meirion
