Hi all. I'm having problems with rendering some piers in a front garden. I built the piers and walls in this garden about 6 years ago, the walls with concrete blocks, the 2 piers with bricks. The rendering I did on all the concrete block walls is still fine, but it has fallen off the piers twice now.... the first time about 2 years after it was first done (I rendered it again then), and then again about 2 years after that. I cleaned it all off the other day, most of it came off really easily in big pieces. The bricks are cheap face bricks, can't remember exactly what type (not flettons or engineering). The second time I rendered it was careful with preparing the bricks (cleaning, PVA etc.) and with the mix - 6:1, waterproofer in the scratch coat etc..
Obviously the bricks are the problem, as I said, all the rendering on the blockwork (about 30m2) is good, and usually my rendering is successful... The bricks are damp, but that is probably because the rain has been getting in the cracks in the render and not drying out.
So any advice on what I should do would be gratefully received. Is there a special key coat I should use? (Blue Grit?), maybe SS expanded mesh? I didn't use any lime, but never do...
Thanks in advance
Thanks in advance
