Powerfloat/sponge
Jay 797
I've just bought myself a new toy hoping to save some aching shoulders & elbows!
My question is & I know I'm going to get ripped for asking but I'm going to ask anyway....
At what stage do you use the sponge & what sponge for what product?
I've tried it today on some OCR with the far left hand sponge & made hard work for myself as a result!! Do you use it when you would normally use a float or wait a bit longer &use it when it's gone off a bit more & use a bit of water?
I know it's going to be a bit of a trial & error until I get used to it but if you guys that have one can let me know what process you use it would be a great starting point for me?
Cheers
  • Powerfloat/sponge
I’ve still got to use mine yet but I’d imagine let it go a bit. i bar it and then water and sponge.
I’ve not got one or used one but just guessing it maybe to cold atm to use them
good thread I bought one in summer for any dodgy overnighters mono but interested in OCR as I havnt used it for that yet,the scratch pads dont last two minutes on a bad day and expensive as f**k to replace,going to
Cheers
I bought one in the summer but the eibenstock one,is this the new cheaper one with more attachments,?I only got one sponge and scratch pad attachment,
I am afraid there is no exact how to and what to with the power float. You need to get your timing right. There are different sponges in the box , which will allow you to hit it at a different point and achieving different finishes. The one you pointing at is dense , if is the same as refina, which should be alright for ocr, but after floating first .
I’ve got the scratch pads but is it not a bit aggressive for scratching? Maybe for emergencies when it’s gone too hard but normal scratching I’m not sure.
There was a site done near my lake where they would put the Parex on on a Friday and sometimes not scratch it back until Tuesday or Wednesday! It looks surprisingly good considering.
aye they get you out of trouble done a few overnighters late summer and there great for that hence pads dont last two minutes.weve had a few roofing truss plates made up the same size cheap as f**k.havnt had chance to try them but look identical
That’s a crackin idea! Like that one
The power floats should be sold wit all different attachments. That way u can play with them all and find what's best for u. I personally didn't get on with the power float. But only had 3 different attachments. I give my one to my mate. He likes it on bace coats. Iv never looked for it back.
Do these things make arms ache holding them up , watched a few videos thinking I kind of don’t want to cut out sponge float using my arms as that’s the most enjoyable part especially last rub , holding it up looks hard work on the shoulders and torso
Yes I thought the same Pete. I mean put a sponge over after floating is hardly hard work is it?
U can use them for floating and spongeing. Hard on the arms after a bit. And a c**t around scaffolding bars
I'm also looking for one of these, what brand should I go for, eibenstock?
Are they ant good for K-rend hp-12 or Johnstone HP base coat when doing thin coat?
