Plastering on painted brickwork
Tommytippy
Hi all
Have a victorian property. The predecessor painted the brickwork. I want to render over the top.
I understand you can score it with a grinder
Or
Fix metal mesh to the wall then sand and cement
Or
Is there another method with fibre mesh and say a K-REND system that will go straight on?
Any advice as to the best option would be greatly appreciated. My preferred option would be a coloured K-rend system so I don't need to repaint after.
Tom
If the paint is sound and solid as it were. Parex do a product called Parinter that you can apply. One of the render guys like @Rigsby will know best
Hi all
Or
Or
Tom
K-rend hpx base coat, full fibre mesh & silicone k1 top coat.
Just been to look at two big bay windows that have been added to an old post office. Builder tells me the client wants k rend like the house opposite which is clearly sand and cement probably done 40 + years ago :D
Several options available. Parex do parinter but the paint needs to be clean and sound.
Or angle grind / sand blast it off and use a bonding agent or sticky base render.
Fix expanded metal lathing although I would still use a bonding agent under it. The sort you put on and let dry. Otherwise all you have got is a render carrier. Risk of cracking.
Have spoke to K-rend many times and the only time they have said go over paint their spec was plugging the mesh, saying that though we get told a different thing every time we call them depending on who we speak to
Personally I would use parex parinter.prime then a texture finish
Done a few now and it's a good system
Make sure the paint is sound mind
