Parex is a scraped finish so you shouldn't get any blocks showing through, if you are worried it will suggest a base coat to the builder.
theyre normal concrete blocks! what depth beads should they be?
We did a parex job last week and had to use parex maite as a basecoat horrible stuff sticks to everything.
They might appear to be 'normal' concrete blocks but it all depends on what strength they are. Some manufacturers insist on a min 7.5 newton block otherwise a base coat is required. Most outer skins are 3.5 newton. Check with your chosen manufacturer for min block strength and if required what base coat is needed. Most manufacturers specify a total min thickness of 15mm combined but Weber want 15mm mono on top of a base coat. Cost a mint!
I know I'm not the sharpest but do I detect the fact that you're not........over keen on Weber as an outfit?
I used to use all kinds of s**t then switched to Marmorit..... fantastic gear and the back up is second to none. Why use anything else?
mr logic strikes againJesus rigsby you've had your fair share of bad luck with mono mate! Webers used on load of persimmon sites round my way and although it doesn't look full of cracks....it does get stinking after 3 or 4 years and I mean black with crud off the road etc and green on north facing elevations. Even so they still churn them out at volume regardless.
So as well as cracking issues you mention and a lack of support from them in disputes, it gets dirty in no time. Not the best choice.
Give us a full level 5 diagnostic of your better choice of mono butt when you crack it(eek).
