yes i have steve,
hand applied it and sprayed
is it a flat substrate your applying it to, or are you building it out in coats? depend what substrate you are applying it to aswell, we put a primer on prior in each case before and clair was applied.
you dont want to put more than 10mm of clair on at a time, if you are it needs a day per 10mm to cure, to apply and spray its pretty much the same as standard monorex.just give it a drink of water before you apply the top coat.
the only differance with the moyen it takes longer to go off ready for scratching, we applied it first thing in the morning and left it to the following morning and it was spot on but it was a cool day.
and wear a mask when scratching back and goggles as the lime particles get everywhere.
