Opinions on over skimming?!
jacktheladd
What are your opinions on over skimming? im curious how other people do it if you are doing a job the same day do you put on two coats of pva and away you go, or can you plaster straight over this new stablising primer/plasters pre grit?
Another quick question how do you over skim atter ceilings the same day aswell?!
thanks im advance :RpS_thumbup:
This has been covered soooo many times jacktheladd search for old threads. There is a current thread called Wickes pva which may help you out.
The Stabilising grit stuff has to dry :-) I use to lay that on the day before :-)
PVA is also fine, I leave it to go hard where I can to be honest.
For the artex ceiling once the pva is ready and its a heavy artex put a few handful of bonding in the first coat of multi finish so you can cover all the artex .makes the second coat a lot easer .good luck
