User________removed
Right guys bit of help needed please.
I will be rendering me old man's garage for him as and when, its all new 3.5 kn block work. Im a traditional S&C bloke but decided to the the plunge and use a thro coloured OCR system. done a bit of research and decided on Weber OCR 3 because it seems to be applied and rubbed up the same way as S&C, and have a similar finish.
What i need to know is :
Any other hints or tips much appreciated.
AB
- Do i still need to scratch with this stuff or can i go straight on at 16mm ?
- Do i need to hose the wall down prior to laying it on ?
- Me paddle mixer or cement mixer ?
- Taking into account different backgrounds how long does it hang around for ? can you get plenty on before ruling off ?
- How long before rubbing up ? is it similar to S&C ?
- Do you dry sponge after rubbing up ?
AB
