New mtec 200 machine pro set
LukeGodfrey
Hi me and the lads are work got mtec 200 sprayer and was wondering if you guys would advice us using a 20 metre hose we only been using machine for a week or. We tried the other day and it just was not coming out the hose at all we are using Webber chalk and just would love to advice for newbies to the machine. We keep having problems with water and air pressures and we run the machine at speed 3 as advised to us. as we are all new to the spraying life cheers in advance
Elite exteriors
Are you getting gear through the pressure plate before you attach the mortar hose and if so are you priming the mortar hose before you try and run gear through it
Nottsb
Like elite said mate run just water through the pink before you put any gear in then just run a couple of handfuls of gear though without the hose on before you start just to prime it, and run water through the hose before you start and dunk your gun in your water barrel
owls
If it’s any consolation we’ve all been there, could be a number of issues.
Hi , did u sort it as we had a few issues too, same product
Tramp
Make sure you lube up material hose, prime chamber probably and start up full speed.
