Need help with plasterboard
Ibbo2020
Hi Everyone,
We have recently attached plasterboard to the inside of our summerhouse to convert it into a bar. We aren't professional's but we have done this before. We have taped the edges and skimmed.
The problem we have is that the door and windows are set back from the walls and are obviously wooden. This has left a visible edge of the plasterboard and with nothing to attach it too, I'm stuck slightly. I thought adding the plastic edge bead wouldn't work or the metal edge.
I really want to close the edges off with a smooth finish but also blend them into the window and door frames so it looks like a professional finish. I can't plasterboard over the frames as they are about 10mm in depth and the doors swing out. Is there anything I can buy that will clean these edges up?
Sorry if this sounds clumsy, I'm a joiner not a plasterer !!
raggles
UPVC flat trim comes in a 5m length and various colours most builder's merchants will sell it in various widths from 25mm up to 150mms or more. Stick it on with no nails or similar and silicon all your gaps and edges.
Ibbo2020
Thank you. I will look at that in the morning.
Cockney1
What do joiners look like?
TonyM
You’re a joiner and you can’t think of a way to cover the edge of the plasterboard?
How about a rebated architrave to ‘frame’ the opening? Surely that is within your capabilities.
ChrispyUK
Hi Everyone,
photos?
Ibbo2020
I have sorted it now. Thank you for your help
