Monocouche over decorative stone
Marc T
I'd like to render over a small section of decorative stone and really need some advice or the correct method.
I'd planned to use weber pral m, just because this is the product I have done the most research on.
I was going to apply rendaid as a key, then use one coat base render with mesh to level off the uneven surface. Apply 10mm beads and finally the coloured weberpral m ocr.
I have already taken the extreme high points off the stone but there is still about 15mm Maybe even 20mm in some places.
Have I missed anything from the plan or am I headed for a nightmare.
Thanks for any advice.
I would finish with a thin coat acrylic, not mono.
acrylic finishes off quickly, with mono you will be waiting about for hours.
Yeah you could do that
