Deffo full mesh Rhys and I would use a pre rend.
Not a bad thing John , i would mateIs mesh needed in ocr too on lightweights,? Would render grit and two passes suffice or not?
Cheers,would you grit concrete blocks for ocr ? Mesh or just weak spots..?Not a bad thing John , i would mate
As said before John ,bit of a weber pral , one trick pony mate ,mesh the lot with first pass in my mind , for what that is worth :RpS_unsure:Cheers,would you grit concrete blocks for ocr ? Mesh or just weak spots..?
You're my go to guy now.!As said before John ,bit of a weber pral , one trick pony mate ,mesh the lot with first pass in my mind , for what that is worth :RpS_unsure:
What do you think Keith, could it happen...Bromance...................:RpS_wub:
Thanks@Arti for your kind words :rolleyes) , i will say it again ...YOU NEED HELP MATEmake sure you bag up asif, he's a dirt bag
