Mm21 or mm30?
Looking to get a mega mixer and was going to purchase the mm21 but I've found a canny bargain on the mm30. I work mainly domestic so never have a need to mix more than a 3 bag mix and often may only mix 1 bag. So I'm guessing the mm30 will be a bit over kill?
Can anyone advise or let me know which your using?
Go for the big one - things in the future may change for you workwise and if you have it and need to mix render/screed you have the bigger power.
Had the same dilemma 6 mth ago, I got it £70 cheaper so no brainer, the guys are right maybe a bit of overkill, but it is a beast
Check the weight as well, it's a heavy beast!
