well it's a angle bead would be used for rendering . If needs must you will need to put skim on a bit thicker . Just make sure your bead is well tight to surface your skimming onto.
I've just bought a sponge float after reading lots of good stuff on it. Looking forward to giving it a try, especially since the plaster I'm using - Lutece 2000L - goes off pretty quickly before you get a chance to flatten it properly. My weapon so far has been the spray bottle.
