Help with insulation please :)
#1
Hi . Just wondering if anyone can provide any advice . We are currently renovating a cottage which is approx 350 years old . We’re just at the stage of starting to insulate and we’re advised to batten out and insulate that way therefore hiding all pipework etc . However , I’ve recently read an article and have been put off that idea as worried about trapping in the moisture . I’ve read about hemp lime plaster and like that idea as it apparently allows walls the breathe etc but not sure how we would hide pipework ? So confused , please help !
#3
Where are you based ? DO NOT BATTEN OUT AND INSULATE!!!!!!!!
You should use only breathable plaster/render on the wall. Hemp lime is good, but in your case lime with cork might be best. Another option is Bauwer light , which in my opinion is best.All 3 are breathable and insulating renders .
JessThePlasterer
Queen Jess Elizabeth I
#4
Knew you and smarties would have the answer!
t33ch
How thick are the walls? If you can, core through some vents and then stud/batten and insulate.
Otherwise you'll have to use a lime based plaster and freeze to death in winter.
I'm guessing that there's no heritage/listed status on the building. Better check in case you pay for work and then pay for it to be ripped out again.
#8
Why bother with battens when he can go strait with bonding ?
t33ch
Best insulation out there
Fag packet calc shows that you only need about 375mm of bonding to match a 50mm insulation board. At least it saves lugging those cumbersome sheets of insulatoin about ;)
