Hello everyone, any tips on plastering/skimming around windows?
Pcurado
Hello all, I have 4 windows that need a bit of TLC (plastering) but as you can se from the pictures I most likely don't need to plaster everything just until where it meets the paint.
However I'm not sure if plastering up to the upvc is a good idea and was wondering if anyone had some thoughts.
I've looked at stop beads but I would have to re-plaster quite a bit given the 3mm width of the bead. Which to be fair the remaining surrounding of the window is pretty solid.
Also looked at something called tear away beads, not sure if anyone had experience with those if it would work in this case.
Any help will be appreciated.
  • Hello everyone, any tips on plastering/skimming around windows?
If reveals are solid, stick a 9.5mm board or even 6mm if they stock them near you over the top and bead then feather in on the face or skim the whole wall. :sorprendido3:
