No don't touch the speed as it comes out like piss on low speed as I found outTurn water on![]()
Don't ring me if you f**k it up as I know s**t about machinesNo don't touch the speed as it comes out like piss on low speed as I found out![]()
Ok boss keep the bat phone onI'll be on standby captain
Did you get the water pump with it ?No don't touch the speed as it comes out like piss on low speed as I found out![]()
Yep it's a dreamDid you get the water pump with it ?
Is your number an 0800 number? [emoji6]1 call was all it took![]()
1h 1/2 I'd say it was me spraying my old man ruling off and my apprentice on the machine . No never used one as I'm new to the machine world ?Nice work maz how long did it take to get that on and how many blokes were on it?
Have you used 3 phase mate it's be nice to have a comparison
It will be worn in line with where the water enters the mixing chamber
A worn mixing paddle will knock the gear up very poorly
I feel your pain bud, I used mine for the first time yesterday. Complete disaster and what a mess lol what should have been the easiest day in weeks turned out to be the worst.Second time of using the Ritmo tomorrow so fingers crossed I don't f**k it up again other wise it's hand balling 30 bags
What did you do worngI feel your pain bud, I used mine for the first time yesterday. Complete disaster and what a mess lol what should have been the easiest day in weeks turned out to be the worst.
I let the hopper get too low and gear started getting pissy so adjusted the water and ended up with a blockage half the wall was on at this point stressing out rang Brian in a panick lol. Cleared out the hopper and flushed pipe tried to spray again, nope wasn't happeningWhat did you do worng
It's all a learning curve I'm using mine again in a few weeks no doubt I'll have some sort of issue lolI let the hopper get too low and gear started getting pissy so adjusted the water and ended up with a blockage half the wall was on at this point stressing out rang Brian in a panick lol. Cleared out the hopper and flushed pipe tried to spray again, nope wasn't happeningpulled out the mixer and finished wall while lab cleaned down machine and turned out it was in the gun.
i reckon about 100-130 tonHow long do you get out of one. My one has only done 70 bags and it looks to be a bit worn
This is my one after 70 odd bags. Don't know if it should look like this or not.i reckon about 100-130 ton
Looks a bit bent to meThis is my one after 70 odd bags. Don't know if it should look like this or not.
That looks like its been bent. Does it knock the hopper when you turn the machine onThis is my one after 70 odd bags. Don't know if it should look like this or not.
No I don't think so. It's never got a bang as it has been all ways in the machineThat looks like its been bent. Does it knock the hopper when you turn the machine on
