gilesy said:just for fun.........
why is it that the sand and cement mix is mixed at ratios of 4:1.5:1 or 6:1? how do you find the correct ratio?
old school plasterers should know the answer plus nvq 3 boys or just clever dicks!!
FreeD said:Rendersystems so what mix would you do on common bricks?
Render Systems said:FreeD said:Rendersystems so what mix would you do on common bricks?
1st coat 5 to 1 second coat 6 to 1 but i would rake out mortar beds also if needed as sand and cement renders and lime renders need a mechanical key for adhesion unlike monocouche renders...
what does he do when theres another variable involved like lime? get his no dont tell me.. ;Dwarriorupnorth said:My brother chopped two fingers off a couple of years ago , so he has to take his shoes and socks off ::
your right church it really does slow the job down
Chris W said:what does he do when theres another variable involved like lime? get his no dont tell me.. ;Dwarriorupnorth said:My brother chopped two fingers off a couple of years ago , so he has to take his shoes and socks off ::
warriorupnorth said:Render Systems said:FreeD said:Rendersystems so what mix would you do on common bricks?
Mono also requires a mechanical key to help adhesion, hence the need for a pre rend etc
Render Systems said:warriorupnorth said:Render Systems said:FreeD said:Rendersystems so what mix would you do on common bricks?
I have never used pre rend on block or brick work.... what materials are you using?
kirk johnstone said:i mix s&c 3-1 mate for top coat and bottom coat. never had any problems![]()
essexandy said:kirk johnstone said:i mix s&c 3-1 mate for top coat and bottom coat. never had any problems![]()
Do you know anything about rendering Kirk?
church said:kirk was the book was written in 1897 ? When did they start using opc ????
church said:
;D ;D ;D ;D ;D ;D ;Dkirk johnstone said:i mix s&c 3-1 mate for top coat and bottom coat. never had any problems![]()
:-* :-* :-* :-* :-* :-* :-*pftmonojetman said:;D ;D ;D ;D ;D ;D ;Dkirk johnstone said:i mix s&c 3-1 mate for top coat and bottom coat. never had any problems![]()
FreeD said:ESSEXANDY you use a weaker mix? what mix do you use on common bricks?
