floor covering - roll and stroll
peterroberts
not sure where i shouldve posted this, any of you guys got a supplier for the plastic sheeting rolls (self adhesive) in or around the north west the guy i used to get mine from has gone under/ jacked it in usually but the 1200 mm x 100 metre rolls was paying £25 a roll any help would be great need some urgent down to last roll found a web site but delivery was shocking on it cheers for the help guys
Hi Peter,
We sell the 500mm x 100m window protection. It is low tack so won't leave any residue. It's £17.90 per roll + vat and delivery will vary on how much you want. One roll will cost about £8.00
Hope this helps
Ryan
need a wider version, as that would be a ball ache covering the floor, hence the 1200 mm width, could deal with 1000 but 500 would be too small, do you have a wider version available?
The carpet protect isn't something we really stock to be honest. Afraid the 500 is the largest we do. Will have a hunt around for you and let you know if I find anything
wouldnt like that on stilts, slip slip..............[/QUOTE]
wouldnt really use it in the room ime working in ..
just for covering floor acess to the front door
its great for stairs and hallways ....before this stuff was around had those stairsheets but hated using them (trip hazard )
Link Removed
Link Removed
just tryed stroll and roll for the 1st time on a job where i was knocking a bathroom down to bare brick and thought it was ok but would like to use it in a room i was plastering in plus at £18 for a roll and you only get to use it once isnt good value for money , and you need a different one for hard floors. i fined breathable roofing membrane is better than normal stair runners as it stays flatter that cotton twill!
