Fine hair line cracks!
Hi fellas,
Need to grab some experience again, i've rendered up a wall using sbr as specified by a client, on 1:4 mix, i wetted up the wall before i pinked it but now theres very small hairline cracks appearing? I've not had this happen on using normal add mixtures any one come across this before,
Ready to recieve help.
I bet the render wasn't allowed to cure for long enough before it was skimmed and was still shrinking.
i used an sbr slurry onto a backing coat, i rendered it about 24 hours later, however airblowers were used after as there was a burst pipe onto the floor could this be my problem?
The blowers certainly wouldn't have helped but render should be left longer than 24hours before skimming, cracking can occur to a greater or lesser extent depending on the cleanliness of the sand used. Blowers have a greater effect on skimming that has been applied thicker than it should be.
Though that may have been it, how long would you recommed leaving the render before skimming for future referance?
Personally I leave for 5 days minimum but I know that this isn't always possible for others due to pressure from the clients
