josel
Hi all, I have seen some plasterers using clout nails to place external corner beads against old plaster. Then seen some using a mixture of nails and screws into drywall 9.5mm. Others use bonding plaster to attach the beading.
Then most use multifinsih plaster when plastering over the beading, regardless if it is drywall or old plaster.
I know each plasterer works diffently but wanting to find out the correct way of doing it as i about to renovate a house.
Thank you in advanced.
