ewi
wil
Just after a bit of direction please anyone, when applying the insulation to block work what is best foam application or adhesive mix and what brands?also at what point are the fixings put in at the same time or later any advice would be a great help thanks
Am using 90mm depth on the insulation slab size it's java board type not sure of brand off the top of my head,not done this part but used the k render products
