Is it a part of the kilsaran range?Hi guys, has any of you used the brand ceresit? I normally use jub but I am pricing a mate of mine up so trying to do it cheap and this brand is a third cheaper I'm told the silicone top coat is very good can anyone confirm that thanks
Have you used the Nanoxil 1.5 Dansouth,if you have is it similar to use as their normal 1.5 and how much dearer is it than the normal one , its funny that you get 12m2 out of the Nanoxil rather than the usual 10m2Never heard of it. But cheap isnt always best tho. I use jub for my works. Wouldnt use a cheaper alternative that you never used just because of price
Yes mate nice gear to rub it. Feels sticky to apply because of the higher silicone content though.Have you used the Nanoxil 1.5 Dansouth,if you have is it similar to use as their normal 1.5 and how much dearer is it than the normal one , its funny that you get 12m2 out of the Nanoxil rather than the usual 10m2
Im thinking of buying a machine. When u spray your topcoat do you still rub it up?That's what I normally use Jub Nanoxil 1.5 it sprays lovely too![]()
Id like to see the difference in finishDansouthcoast no mate spray it and that's it slightly different finish than by hand but I like it loads better flawless finish and you can cover some silly m2![]()
It's more of a tyrolean finish dan.still looks tidy though.most customers want a flat finish not a tyro typeId like to see the difference in finish
What you saying then bobby. Forget spraying it. LolIt's more of a tyrolean finish dan.still looks tidy though.most customers want a flat finish not a tyro type
Thats the thing. Clients like the troweld flat finish. Always hear i want a smooth finish. Never a tyrolean finishThe major difference between hand applied top coat and sprayed is the first one looks great from close distance, machine sprayed- from across the road.Its not bad, but you have to experiment with the speed,distance from the wall,with or without adding water to the top coat .........until you get it right. Don't take for granted the instructions how to apply the top coat given by the machine gurus .You will be surprised how small changes can make big difference to the final product.Once you there it's a great feeling.
I know what you mean . Many contractors do not allow machine to be be used, mainly for this reaso. I am seeing on here many times how people do 500m2+ with machine, but then when you look close you can see the primer at the back . The best I have ever managed on my own is 130m2, but I had to go back and put a bit more to come close to the hand finish. As I said you will spend some time experimenting until you find the finish you are happy with. Forgot to mention this trick of mine - first coat I do a bit wet and the second time no water to the top coat at all. It depends what top coat you are using too, I am referring at the shape of the stones here. The more round the better. The finish is really nice. For instance 1.5mm finish from different brands the crystals are always with diferent shape. Nothing is more annoying than having a few swirls on your top coat finish and here is were the machine comes.Yes, it's not the same , but you can come close and the consistency is the winner. I think you should hire one and see for your self Dan.Thats the thing. Clients like the troweld flat finish. Always hear i want a smooth finish. Never a tyrolean finish
Well on a good day with 2 spreads and a labourer we can top 100-130m and clean up. So not much in it then really except being f**k*d at end of day. Maybe try spraying at float it option. Would that work?Or try to get more on the wall and go with the finishing spatula over it.
