Dot and dab onto tanked wall
markyyyyyy
Am applying 2 coats of tanking slurry on to a 9" solid wall, followed by dot and dab insulated plasterboard.
Cant use foam as the walll is not level/flat in many places
I also want to make my wall vertically level hence dot dab.
Do I need to apply a primer onto the dried tanking slurry before dot and dab adhesive? I need to wait a mo th before boarding as I need new doors and windows.
Cockney1
@John j
TonyM
Think you need a tight scratch coat or you’ll get dabs showing through on the boards, as the tanking slurry will condensate
Andy R
You will need a primer or PVA because The drywall adhesive will not adhere to the tanking properly. The dots can pop of the tanking when dried if the board is hit.
D
Deleted member 46546
Guest
Can't dot and dab onto tanking slurry. Thread closed
