Dabbing
jamesthefirst
What do you use to hit your boards with?
I need to get something new to replace mine which I’ve found to be a bit light.
don't do enough of it to comment but when called for short 4x2 and if needed a rubber mallet and check with 6ft level
Use feather edge to tap. You can see if it’s straight at the same time. Tap all boards then go over with level and adjust if needed
Vagina my arse... Ste V en
Like V for Viagra...what makes you a goddamn sexual Tyrannosuarus.
RARRRR look out Johnathen.
Dabbing
