Ceiling plus two walls req insulated board and plastered NW10 london
coolhands
Hi
I need two walls fitting with insulated plasterboard Gyproc ThermaLine 40mm dot & dabbed etc then skimmed after; and also the ceiling doing. I've fitted gyproc soundblock to the ceiling. Ideally I would like the edges against the wall filled before it is skimmed to try and reduce noise transfer from the flat upstairs. The two walls I would like insulated plasterboard fitted to & then skimmed are the main square wall on the left up to the pillar, and the wall with the window in (ie all round the window). The reason is because the room is cold, it has 12 inch thick solid brick walls house built approx 1905. The reason for not doing the others is because the wall to the right of the window is mostly chimney breast so not worth doing. I know it's not a perfect solution but it's what I want, as I've also just fitted a second rad so the room will be ok with this. Here are some pics so you can gauge the size and job.
postcode is nw10 8ts. I can sort parking permit so you don't need change etc. (resident parking everywhere these days!)
ceiling:
square wall req insulating and skimming:
the back wall with the window in that reqs insulation and then skimming:
Hello mate
are you still looking for someone to do your plastering work,if your interested my number is 07713198699 give me a bell and we can chat prices thanks.
looks like they were taken through a spyhole in the front door. is this your property :RpS_confused:
I don't get why 2 people dislike my post clarifying what needs doing on the ceiling as it wasn't clear in my first post.
Dont know why either mate ???? Must of clicked it by accident with my sausage fingers:RpS_unsure:...a thousand apoligies:RpS_blushing:
cheers
well I've made contact with Phil 'rapidspread' so fingers crossed. By the way should I remove the wallpaper or doesn't it matter?
Sent him some better pics plus measurements, here you are out of interest:
Well rapidspread and his lads did a fantastic job so big thanks & comes highly recommended :RpS_laugh: I will be using him again for some other jobs. Looks great and I was worried about what to do with the window reveal, (cos of the depth of the insulated plasterboard) but he squared it all up and it looks great.
