Braces (Suspenders) for work trousers and belts.
Wayners
Perry make braces that will clip to belt vs crocodile clips. Just got a pair from ebay from America for under £20. Also available in the UK. Those metal crocodile clips on some can come off so these plastic belt hooks are a really good idea
Tushi belts are good although you have to remove buckle to thread through loops. They make 2 types and both great like this magnetic catch version
Or mechanical catch
Hammer on buttons work great for but button braces / suspenders sold at screwfix but don't work with belt though. I like to carry stuff on belt pouches. Easy hammer on though on the outside
Brimarc braces X style with clips are easily available in the UK and if your over 6 foot buy tall man length. I buy the wide heavy duty straps.
So to recap
Tushi belts either buckle type..
Perry Y Shape. Only seem to come in Y Shape with the plastic belt hooks. I like these.
Or brimarc with clips.
If you want button fix buy the hammer on buttons 17mm ish.. Think some are 16mm
Belts under £10
Braces (Suspenders) under £20
Wayners
You can also get velcro belt loops. They wrap around the belt.
Also braces with belt loop clasps. Not tried them but hooking on belt loops is also a good idea.
I like to carry fastback knife for board and general cutting plus tape measure and phone holder so belt is important with the weight.
I've had belts done up so tight it hurts plus its put my back out and yet trousers constantly need pulling up. Must be great for some hanging stuff off belt no problem. Not me though.
Remember builders bum on a job many years ago and lady customer shouted at them. Can't say it was a pretty picture although I cracked up.
Belt loop clasp type here https://www.amazon.co.uk/dp/B0722KF...abc_475WA6SQ5F3XA82R4WH1?_encoding=UTF8&psc=1
Anyone gone for the heavy duty drill driver and hammer tool belt braces? Some you can hang a chain saw off or other heavy tools. Clever..
D
Deleted member 49960
Guest
If you wear braces just remember to put a vest under your T shirt !! I tryed them once without and my nipples was like pups noses !! Never again I tell ya !!! 8 hours of chaffing !!!!!!!!
Wayners
St
Straps in wrong place at the front. Need to be out the side a tad more and it fine away so no joggers nipple. Lol.
Too far out straps fall off shoulder so need to be in correct spot for you. No grandfathers or others to pass on this information I guess. Cotton sting vests are great and much cooler vs the thermal that's too hot. They are much longer in the body if you want a vest I'd recommend them. I prefer to hide braces vs over the top of t shirts on show as it's more a statement I think. Some can carry it off while others look a idiot and a bit blue oyster
Wayners
That's it. Da da da da du du du. Classic. Brilliant bit of comedy. :)
Other problem is. People tighten straps. You get shoulder pain or back pain. Need to be slack and loose when stood up.Your general movement will keep trousers up and should not know you got them on.
D
Guest
St
Wayners
Anyone know the way to tie laces so they don't come undone yet you can still pull the end as normal. That was another frustration of mine. Seems sometimes ladders and on your feat all day causes laces to come loose. Maybe a post for another day as I know..
Cockney1
What are those SITE joggers like from B&Q @ Cockney1? Any good me ol fruit?
Sorry I can’t help you I don’t shop there. I wear snickers work trousers and I can throughly recommend them (y) They do a 34in inside leg.
algeeman
It’s A Boy
Perry make braces that will clip to belt vs crocodile clips. Just got a pair from ebay from America for under £20. Also available in the UK. Those metal crocodile clips on some can come off so these plastic belt hooks are a really good idea View attachment 60026
Or mechanical catch
Hammer on buttons work great for but button braces / suspenders sold at screwfix but don't work with belt though. I like to carry stuff on belt pouches. Easy hammer on though on the outside View attachment 60030
So to recap
Belts under £10
looks like parts of my kids pram
