Bluegrit/plaziflex
Brian1974
i usually blue grit day before skimming has anyone done it same day with good results.also is the plaziflex worth buying ive not tried them yet?
bobski
Blue grit - not same day
Use wickes bonding agent or microgobetis (parex) as stated above usually set in an hour!
Plazzi's are hit and miss
Don't like the trowels (plaziflex trowels) but the rules are fine, nice roll grip.
Basically another version of a speedskim
Stevieo
Royal Spin Doctor
Manufacturer spec us there for a reason.
Even if someone on here tells you it'll be fine, you'll both look stupid if it shells off in 6 months won't you?
