It can't be a proper blockage if the Ball still comes through,Has anyone got any ideas on how to unblock a 25mm material hose on the ritmo? I can get water and the cleaning ball through but the render gets clogged and jams the machine
I think you’re right, driving me insane. I’ll get the acid on it, how do it put the paste in? Just gravity feed from hanging the hose?It can't be a proper blockage if the Ball still comes through,
The inner wall must be caked up a bit with render sucking the moisture out of the new gear as it comes down the tube,
Block the one end and poor diluted brick acid down and leave it overnight,
Before you use in future stick some diluted wallpaper paste down the tube.
Not sure about doing that with mono thoughon the screed pumps we pour diesel down the tube to lubricate it before we start.
I just knock up a sachet of wallpaper paste with a gallon of water put it in an old PVA tub and before a spray tip a couple of litres down the house and lift the hose until it comes out the other side into a bucket and then you can keep it for the next timeI think you’re right, driving me insane. I’ll get the acid on it, how do it put the paste in? Just gravity feed from hanging the hose?
I’m about to order from ian but I want to try an salvage the old one too as it’s not had much use and I can spend time over Xmas sorting itCould buy a new one too mate I blocked my original one up in summer and just left it on the job was sick of trying to clear it
I've got them years of age if you clean it out to all be fine and handy to have spare one'sI’m about to order from ian but I want to try an salvage the old one too as it’s not had much use and I can spend time over Xmas sorting it
Are you sure you're from Yorkshire?Could buy a new one too mate I blocked my original one up in summer and just left it on the job was sick of trying to clear it
not done this for years but we used something called moly slipon the screed pumps we pour diesel down the tube to lubricate it before we start.
Moly slip is a two step dance move I’ve been perfecting for years um ts um ts um ts um tsnot done this for years but we used something called moly slip
what u drinking must be stronger than my rum lolMoly slip is a two step dance move I’ve been perfecting for years um ts um ts um ts um ts
Bleach mate, I’ve got Covidwhat u drinking must be stronger than my rum lol
so sorry to hear that [lying c**t lol]Bleach mate, I’ve got Covid
I’m lying about the bleach but not the Covid mateso sorry to hear that [lying c**t lol]
it wont be a blood clot alchol thins the bloodDo you mean you have a “blocked nose” because you got COVID?
I should go back and get it really and have a go clearing it out the while lot was blocked I got so pissed off just drove off in the endAre you sure you're from Yorkshire?
Put the house on the road drive up and down it. Put it back on the tap of the machine use the pump to put water down it. If it doesn't work repeat it till it does. Bend the hose to and whip it. I've got render out of a hose that was in it 5 years b4.
Cheers mate, I can get water through just not render.The first time u use it after u unblock it. Wet the hose put some wallpaper paste in the end of the hose that connects to the machine. Let the render push the wallpaper paste trough the hose
Driving on it will sort it outCheers mate, I can get water through just not render.
