I.m gutted really wanted it to be a successB@q must of lost millions I be surprised if make good don’t finish them off!finish them off!!! How ironic![]()
Is it that bad? What the problem whith?
Haven’t used it myself but it’s probably like the knauf s**t that was thrust upon us in the early 2000,s when there was problems at the plantI really had high hopes for it too,thought it could have been a bit of competition for Bg ....
Ah well![]()
At least you don't have to paint it lolI used it on my ceiling only a two bagger on artex was lovely to spread and flatten ect no bubbles and has painted up lovely but it was very hard work on last two trowels just went like a rocket!! Excuse the lamp it’s temporaryView attachment 54149
Could be reviews from lads that can't handle a trowel.I’ve never used it m8 , just seen the bad reviews on here.
gone from £7 to £4 to £2 and now this .
I wonder if that extra time would make a difrent to setting timeI used it on my ceiling only a two bagger on artex was lovely to spread and flatten ect no bubbles and has painted up lovely but it was very hard work on last two trowels just went like a rocket!! Excuse the lamp it’s temporaryView attachment 54149
Might do!get ya self a coupe of bags and give it a whirl m8
May do it’s funny stuff hanged for ages then I put plasiflex over it and all of a sudden it went like a rocket I chased it and threw loads of water at it! Something I never do with multi use hardly any water at all tbh!I wonder if that extra time would make a difrent to setting time
@Plasterers1StopShop what’s happening
Hopefully its opened up an opportunityBiggest own goal ever real shame they missed thr opportunity for us as a trade
EhHopefully its opened up an opportunity
For some one else to try
Any 13 inch carbons in yet. Think mine popped a rivetI believe they are clearing old batches - however. I’m not 100% sure.
They obviously messed up big style with the first batches and have hurt their reputation - however, they did listen and have changed things to overcome issues.
We have had great feedback and results on the second batch, but have withdrawn it from our lines due to the current situation with B&Q and the confusion surrounding it all.
I used second batch application wasn’t a problem it was the work it took on the final two trowels I got a A1 finish but bloody hell it made me work plastering should be pretty effortless to a pro it wasn’t the case with this stuff ( this was going over artex with the suction killed with pva previous day) on board I found it better but still seem to work harder on the trowelI believe they are clearing old batches - however. I’m not 100% sure.
That's exactly how the Knauf finish worked.May do it’s funny stuff hanged for ages then I put plasiflex over it and all of a sudden it went like a rocket I chased it and threw loads of water at it! Something I never do with multi use hardly any water at all tbh!
Yeah couldn’t knock the way it mixed up and spread on the wall just final stages completely let it down!! It’s kinda like casting plaster when it goes it goesThat's exactly how the Knauf finish worked.
Where as multi even if you left on wall For over a hour with hard work you can bring it back! This make good seems to have same chemical make up as a casting plaster or filler where gypsum differs with the slight graininess you can pull back with water if ya get meYeah couldn’t knock the way it mixed up and spread on the wall just final stages completely let it down!! It’s kinda like casting plaster when it goes it goes
So basically they have the same problem that was their in batch 1. It does not set uniformly.Yeah couldn’t knock the way it mixed up and spread on the wall just final stages completely let it down!! It’s kinda like casting plaster when it goes it goes
I think ultimately once the damage has been done they're sunk. Unifinish was a prime example.As I see it, that's the problem - aside from the shortage of BG, which is a topic in itself, I think there has long been a desire, amongst spreads in mainland UK, to see a viable competitor to BG, not necessarily to hurt BG, but just to keep finish plaster at a competitively high standard, on all sides, rather than complacency slipping into the equation due to too much market share, which ends up hurting spreads who have to struggle to achieve a decent finish when a batch is below-par.
When MakeGood appeared (again, I'm ignoring BG shortage during the crisis, for the purposes of this discussion), I suspect there was a reasonable amount of goodwill from mainland UK spreads, who would've liked to see the entry of a viable competitor to the marketplace. What has scuppered that goodwill is a product being pushed through distribution channels that was clearly not fully R&D'd, and many jobs have turned into a bit of a nightmare, when they shouldn't have. To rub salt in the wound, it was being sold, right from the get-go, at the same price as a mature (BG) product.
What the motives were, behind this approach, I've no way of knowing, but end-users have suffered and so, now (inevitably), has the manufacturer. So, yes, I hope lessons have been learned, but I also hope attitudes have been altered in so much as not expecting end-users to pick up the slack for a product that's not been fully R&D'd. Were it not for the BG shortage, I think MG would've been hit even harder by the backlash and scuppered sales.
As things stand, do I want to see MG fail? That very much depends on what their motives were, throughout the whole debacle, and almost none of us can know that, for certain.
If I choose to believe that they were motivated purely by greed and didn't give a damn about end-users, then I could say "good riddance".
If I choose to believe they were just naive and over-eager to enter the market, but with no selfish disregard for potentially making life difficult for end-users, then I suppose I might be willing to sit tight, watch them (wisely) step back from the marketplace, regroup and R&D some more, having learned some painful lessons. Ultimately, I think there is still a general desire to see a viable longterm competitor to BG, but only one that properly R&Ds their product before distributing it to the trade - otherwise, they're just contributing to the problem, rather than their competition helping to improve the problem.
If MG do more R&D and re-enter the market in 6 months time, I might be wiling to give them the benefit of the doubt and at least try a couple of bags, on a non-critical job. Whether that ends up being a good experience for me (and, ultimately, them) is almost entirely in their hands.
