Welcome along baz :RpS_thumbsup: scissors is the fella for that he should along soon now he's been tagged
Welcome along mate , is it the scrape finish you are looking at ,or the 1.5 thin coat ?
Have you done it before mate ,with respect only trying to help out
Have you been on the Weber site?Renders & Decorative Finishes - Weber , @Runswithscissors should be along soon ,he is your man to help out , all the best mateNo I'm getting a plasterer in, but just want to make sure he's doing it right
With out a picture mate ,it is hard to say , post something up and we know what to recommendThanks. its more of the stages of application and if I should use mesh and cement boards.
So is it just the bay ? , what is the rest of the house ?why not get a guy in that deals with these systems , rather then checking if someone is going to do it rightAll ive done is taken the old render off back to the stud work and insulated it so far.
You have upset no one my friend , stick around ,it will get sorted ,if we canAll that I am after is some advise, sorry if up set anybody
Hi Baz
See the brochure in my signature below
as you are doing a repair on an existing house, there is no real need for the ventilated cavity. The timber will also have settled, so there should not be alot of settlement to follow either
Fix the Knauf Aquapanel Exterior to the studs, leave a 3-5mm gap between the boards. Mix up the Weber LAC basecoat and push into the gaps, spead over the boards (while the LAC in the gaps is still wet) to apprx 5mm thick, embed the mesh and then skim a further 1mm over the mesh to cover (all while wet). Allow the LAc to fully dry (read the bag label)
Then apply the chosen top coat (with primer, if instructed)
Feel free to contact me - or pass my details onto your renderer, if you like
Richard Lord
Knauf Aquapanel
07918766577
rlord@knauf.co.uk
The Weber render mesh that goes with the LAC basecoat
if you are using an experienced renderer, they will know what ot is and have some offcuts from a roll somewhere
where are you based? might be able to point you at a local Aquapanel exterior stockest
Places like:
CCF, Encon and Travis Perkins will be able to assist with supply of Aquapanel Exterior
Your Renderer may be in a better place to get better rates that you walking in of the street as a cash buyer....
Good Luck!
Ocr render , then tf 150 over to match the bay , if you chosen finishI also forgot to mention that there is a brick wall that runs up the middle of the house and next door, how would you go about boarding that ?
Weber only advise a thin coat as part of this system (for a warranteed system), but as this is a small area on an existing house you could use either....
It depends on what your current house has on it, I would try to match the existing as best i could..... If no current render, I would go with a 1.5 modern thin coat, less likely to crack and easier to clean later on....
I am sure your renderer will know where you can visit and see some examples - there are lots of references in the Leeds area
Good luck!
