Looks like good s**t. You'll have to throw a little review on here.Internal on an old stone wall, spoke to the guys they were quite helpful.
It's only a small wall so thought it was worth a try to see what it's like to use.
It's like being a virgin again haha
So the delivery arrived today ready to try it for the first time tomorrow.
Anyone else tried it yet?
The reviews we are getting are very good. Some say it takes getting used to but everyone is adapting or reacting to the product well
Good to have such good technical support and backup from Alexander as well - he knows the product very well
I'm using the stuff myself this weekend on a old stone wall!
I have 5 bags of light in Sheffield going cheap.
The finish is odd stuff. The first wall went ok but the second? It was like you put two coats on in one go. And the more you trowelled it the wetter it got.
So I lightly sponged it at midday and did something else. 4 pm it smoothed off a bit. I think it will get smoother in the morning.
At worst I will smooth it when hard with a carborundum stone. It is more like thin coat to use.
Just sponge the finish then sponge it again a while later.
Can you use multie over it? Sure I asked @Bauwer and he said yes but can't remember if he said use a primer.
No problem
Think it is about £8 but prefer Limelite finish.To long for me mate rather use lime lite and have it finished within the hour.
How much is the finish a bag?
Looks tidy that. How smooth did it come out? Is it like sponging sand and cement render??
The bond between the two is the primer? I did mention keying the background, also I don't think the breathability (nice word) would be an issue on modern construction?Personally I wouldn't use Multi over Bauwer light.
I would worry about not only the bond between the two but the breathability.
I would advise a lime based breathable plaster. We are currently testing another finish to go over Bauwer and I will update on the results
Bauwer is 2.8 times lighter vs Lime lite in density and 3 times thermally superior as well. It is similar in a way to mineral wool insulation and different from traditional plasters, renders.
For example: Bauwer's key coat is similar to mineral wool mechanical fixings, Bauwer Light is equivalent to mineral wool, Bauwer Finish with mesh in it similar to base coat applied over mineral wool.
Few things are critical during Bauwer application:
- apply key coat, about 80% of the substrate to be covered in a rough coat, photos in the method statement
- wet well the substrate 2-3 hours before Bauwer Light application
- apply mesh within 3mm of Bauwer Finish, both for external and internal applications
Please see photos of the key coat coverage in the up to date method statement:
http://bauwer.co.uk/templates/Default/images/BauwerLightMethodStatement.pdf
Is there any cement in the Bauwer light?
Ha ha make sure you don't get those shoes dirty ryan!!
Are you using a machine?
