Basement wont dry
Adam1976
Been trying to get a basement dry. About 100 years old. The bricks were damp. Tanked all walls, then sand/cement render. Found that the render had wet areas. Thinking that this must be condensation. To attempt to solve this Condensation, I've applied a double coat of breathable lime plaster. Still got the Condensation in places. Any ideas.
  • Basement wont dry
100 years being the age of the property.
If anything, tanking slurry it will of made it worse, @trapping that moisture @can not breath.
As Showing in pics ….
@only use breathable products
Needs it all removing ,back to original/needs good ventilation & needs dehumidification & install some permanent heat
@ control humidity
