MissSoniaJane
Hi all, my daughter and I decided to redecorate our lounge. In the past I’ve just painted over the basic wallpaper we’ve always had. But this time we wanted to add new wallpaper on the one wall. I stripped of the old paper and discovered that some of the plaster was coming away where an old doorway had been bricked up in 1970 I think, and also the skirting board was rotting so have pulled that off too, which has left some holes where it was previously nailed on. The house was built in 1900 and I think the last time any skirting board etc was added was at least 1970, but possibly even older than that. Anyway, I was advised that I needed to use bonding to fill in the holes and gap between the wall depth and where new skirting board is going (to make the wall where the skirting board will go, and even level of that makes sense. As in, so that the skirting has a flat, even surface behind it.) I went to B&Q and bought Thistle undercoat plaster. I couldn’t see anything called bonding so read the description and thought it sounded like what I needed. I used it yesterday on the holes behind the skirting board area and also on the thin strip of bricks where the plaster had come away from where the old doorframe used to be . Basically a horizontal line all the way up the wall about 6cm wide and under 10mm deep where the plaster had come away. I thought it would be right to put a thin layer of the undercoat plaster on there ready to put a layer or filler or plaster over the top to bring it back up level with the rest of the wall. This morning it looks a bit chalky and rubs off fairly easily on the surface I think. Is that how it normally would look before adding a top later or plaster or does it sound like I’ve done something wrong and that if I put plaster on top it will all just flake off. I’m a mum out of her depth here!  Thanks for reading. Sonia x
