1 is it ok to use S&C that u take off with feather edge
2 do u have to use both sponge and poly float when finishing flat render
3 do you put fibers in S&C when rendering
4 whats the deal about rendering in the sun
5 when using drip beads to break up big areas, how do u know where to put them, are they fixed the same distance apart evertime for every job, or do you just fix them were it looks best?
6 how do clean out a cement mixer
7 is it best to buy or hire a cement mixer
8 how do u know, how much materials u need per m2
9 how far from the floor do u attach the bellcast
10 what consistancy do u have S&C
11 how do u know when to use sponge float and when to use poly float
cheers ;D
cheers ;D
