6 month old plasterboard.
des511
Hi
Looking for some advice. Got a room where a couple of the walls have been plaster boarded but
it was done about 6 months ago and there has been no heating in the room since the boards went up.
Do you think that it will need a coat of PVA before skimming just in case it has dried out a bit?
Thanks nelly. I am just worried that I won't find out
how the plaster board will behave until I start skimming
and by then it might be too late.
What mix of PVA do you think?
Maybe a 5 to 1 mix.
i skimmed a wall that had old plasterboard on once, never again. set like f**k and looked streaky. it was no different to any other wall when painted but ill always PVA now
Thank for all your advice. One more qusetion
which is what ratio of the PVA would you
recommend.
